Back story, on board fuel tank was foul. Previous owners let gas cap seal go bad allowing moisture. Added different fuel and heat product and removed the same on three occasions with weeks between each. The last time was a bottle of heat only. A month later added new fuel.
Have installed a nice water separator filter, new pick up valve along with new anti siphon valve, new fuel line and new primer hose and bulb new fuel pump and rebuilt both carbs. Pretty confident at this point the system is ready. So the issue I’m experiencing is the primer bulb never appears to get firm, only slight resistance. The engine will start in this condition, and accelerate and will idle some then die and not immediately restart several try’s later it will run again. I have a spare fuel tank of which I will try to connect after I replace a power pack on port side of engine soon, only running on two cylinders at this time. Any other suggestions ??
