Nasty Wendy
That black canister is simply a vacuum reservoir. It won't matter which hose goes to which fitting. One hose is a little longer than the other which should make it fit better going to the lower fitting. The only thing that matters is the hose that comes from the intake has a check valve in it and that its facing the right way and working. If that check valve is not working the IAB system won't work. Your engine makes *no vacuum while accelerating or while in the upper rpm range so there has to be stored vacuum to operate the IAB while accelerating and maintaining higher rpms.
* Your engine may make a tiny bit of vacuum during acceleration depending on the rate of acceleration and the rpm range in which acceleration is occurring.
