Nylon molded fuel line quick-connect male end broke right outside the (6 year old) engine where it connects to the flexible gas line from the tank. Had to cut the broken piece off to pull it back out of the plug where multiple cables enter the engine from the outside. OEM Replacement male end has a flanged fitting so it won't install through the hole (same diameter as the line/pipe). Any helpful thoughts on best way to approach?
