Inside the pump are 2 poppet valves Both are replaceable. They hold the pressure for up and down.
I backed off the manual release 1 turn the retighten. It’s only the tilt cylinder that leaks down. I have to pull the whole assembly so I go ahead and reseal everything. Thanks for your input.Trash under impact valve in tilt cylinder and damaged o-ring/valve on manual release will cause this.
Not familiar with the impact valve. Is it external or inside the tilt cylinder?Trash under impact valve in tilt cylinder and damaged o-ring/valve on manual release will cause this.
thanksInside the cylinder attached to the rod
