rhartman421
Hello all, on this 1965 evinrude 40hp after removing it from the boat I am getting nothing from the keystart?
for testing purposes I was able to jump the relay and get the motor to start but the key is not even giving a click from the starter solenoid. There were 2-3 lights mounted in the wire harness I did remove, maybe one could have been a man ground, they were all connected to one toggle switch.
Starter solenoid and keyswitch are about 3 weeks old, recently installed. my guess is I knocked a wire lose somewhere in the harness? I sanded and cleaned the battery terminals as well as all starter relay connections and ground.
the motor ran when bypassing the keyswitch at the starter relay. Where should I look? If i wanted to replace the 10 bay wire terminal connector where can I get one?
