I have a 1977( I think) 75hp Evinrude model #75743S
Idles Rough and When the boat is on the water and I try to accelerate it just bogs down. I used to be able to push the choke a couple times while it was bogging down and it would pick up a couple times then take off and run fine on acceleration. That no longer helps. One thing I notice is when I push the choke at idle there is fuel coming out of the carbs is that normal or float set to high?
Things I have done:
Confirmed 3/8 gap spark
Replaced spark plugs
Cleaned carbs
cylinder balance test (all 3 cyl. are firing)
Sprayed oil/Gas mixture in carbs at idle to see if running lean ( all cylinders bogged down )
Any help very much appreciated
