I have a 1972 125hp johnson outboard. the power head runs really well and starts real easy but this year when I went to use the boat it wouldn't go into forward gear, it goes into neutral and reverse fine. I checked the power to solenoids and the switch in the controller and all of that is fine. from what I understand is that if it will go into reverse then both solenoids need to be working if I am reading this right then neutral needs power to the green wire and for reverse the power needs to be to the green and the blue wire both. all that is good. In forward position there is no power to either wire. any ideas? and thank you for reading this
