Hi folks,
spent a a good amount of time last summer getting a 1975 15 hp model 15554c, serial E0002504 back in good working order. Main issues were starting and stalling out. idle mix screw had no effect on performance so rebuilt carb with new float, new water pump, new fuel pump, was not perfect but running very smooth. Next week wouldn't start, ohm'd the coils and they were both bad. Replaced both coils fired right up and started amazingly easy(obviously coils were big part of issues). Didn't test it on the lake and decided to go the next step and replace the points and condensers. Set .020 gap when on the set part of the crank etc. ever since then at low throttle settings tends to vibrate until throttle is 1/3 open then smooths out and engine has good top end power. Also should not replaced plugs with iridium S that were one step hotter as my brother trolls a lot for trout and wanted to keep plugs from fouling.
Any my ideas why it may vibrate? Recheck the points?
