Hello everyone, so I’m have an issue with my 1975 Johnson 85hp power shift II. The boat has been sitting for 8 years. I’m currently not getting any spark. I’ve followed the CDI troubleshooting guide.
I’ve got a brand new battery.
Compression test is 120psi-125 on all 4 cylinders.
Removed the yellow/back wire from the power pack (still no spark).
I removed both yellow regulator/rectifier wires from the terminal block (still no spark).
I remover both stator wires from the terminal block and measured resistance between the brown wire and the brown/yellow wire coming off the stator.
(632.8ohms). (Original stator with spec for ohm reading)
Hooked up my DVA to my multi meter and set to dc voltage hooked 1 lead to the brown wire and the other lead to the brown/yellow wires and cranked the engine. Only measuring 60volts.
With that reading I’m saying I need to start with replacing the stator. Just want some input to see if I am performing the test correctly before I spend money on a new stator.
Last time boat was running I had replaced power pack, spark plugs, all 4 coils and wires, regulator/rectifier, and the trigger/timing base all from CDI.
Any input would be greatly appreciated
