Post to YouTube then post a link.I just replaced impeller and termostat. Put motor in tank and ran. water peeing out as it should. Now I have water coming out either side at bottom of pivot ponit. I have a video but i can't figure out how to post.
I posted it. Still trying to figure out this sitePost to YouTube then post a link.
Yup, your correct. Brain fart. Would the explain water shooting out either side as video shows. My impellor is pumping as water is coming out pee hole. Is there an explanation why I have water coming out sides at pivot point.Not nearly enough water in your bucket !!!----Water needs to be 6 / 8" ABOVE the impeller.----You risk damage to pump and motor running the way you are !
Made sure bucket full. Level was well above water intake. No cavitation. Water still going out at pivot point as well coming our hole at top of leg.Yup, your correct. Brain fart. Would the explain water shooting out either side as video shows. My impellor is pumping as water is coming out pee hole. Is there an explanation why I have water coming out sides at pivot point.
