michael8832
i have a 1975 johnson 25 hp and im having trouble keeping it running.
back story- bought this motor of marketplace. it had compression and spark so i picked it up. long story short, after a minute of running the to spark plug is soaked in oil causing sputtering and misfires. every time i take it out and clean it, within a few seconds it starts up again.
i thought it might be bad rings, but the compression text holds at 120ish both cylinders. quick question, can compression be solid and still allow to much fuel into the cylinder? its only the top one. the oil mix is spot on, and I tried a few different cans to be sure. the bottom spark plug is clean and fires true every time. im sure its the only thing keeping it going.
i have found that my needle value is flattened and no longer a needle. could that be allowing too much fuel through my carb only affecting one cylinder? could it be leaf valve allowing too much fuel into the top cylinder?
if anyone has any advice i would really appreciate it. i was about to pull the rings, but I'm not sure that's necessary with it holding 120 compressions
