1978 Johnson 35 35EL78R powerhead swap compatibility
Hubertcj
I've got a 1978 Johnson 35EL78R with a bad cylinder. Engine overheated and cylinders are now scored up pretty badly. I was going to rebuild, but it looks cheaper to buy a used powerhead with good compression off eBay. Are the later year powerheads compatible with this model? I've looked thru pictures and almost everything looks the same like it should just bolt right on. The powerhead I'm looking at is a 1986-1989 E30ECDW. Literally everything s the same except the casting pattern for where the water tube goes but the one I have should definitely still fit.
Any advice? The powerhead I'm looking at has 125/130 lb compression.
Right, try giving Tim's Outboard in Hackensack MN 218 682 2331 Mike or Dan. Perhaps they can help direct you.
