Hey folks, we are getting close to having a decent engine I hope. Recently had a few days on the water and last 2 trips were rough. Here's what happens.
Start of the day motor is running nice and smooth no issues. Run for about 30 minutes at a combo of idling thru no wake zones and full throttle outside of them, and then the motor cuts to super low power. Basically won't run at above idle at full throttle and it runs sloppy. Pull the plugs and they are soaked and lightly fouled with oil. It's done this 3 times in the last few trips.
What I've tried: better plugs, dump out the gas and start with a fresh mixture at 50:1 ratio, mild idle screw adjustment, took the carb of sprayed out everything with carb cleaner and compressed air, lots of cussing. Also it may be important to note compression is around 90 PSI both cylinders but it has been running pretty good with that for a few weeks.
Any ideas? We are close to having a nice running engine. Thanks for your wisdom!
