So my engine starts great, first or second pull cold and when its warm you just need to pull the rope a little bit and it jumps to life. My issue with it now is that I feel like it responds to the throttle a little slowly and boggs a little bit. When I pull the spark leads the engine will keep running on the bottom cylinder when I pull the top but wont keep running when I pull the bottom so I was thinking that maybe the top coil is a bit weak. Would that be a reasonable assumption?
At full throttle it seems to run clean but it needs a while to ramp up to full rpm even without load (in a bucket).
Carb has been cleaned and adjusted correctly recently.
