Northern River
I'm back, got the engine to run good, now no more steering. Seems cable is broken, rack an pinion system, seems like the steering box is sealed. So I guess that you have to replace the rack and pinion assembly with the cable. Since it is an older model, probably the steering wheel too. This rack and pinion is attached with 2 bolts directly to the steering, at the end of a short square socket that engages on the pinion that goes in and through the steering box. What is you opinion, do I have to replace the whole steering system? Thanks for your advice.
