I replace the both cylinders and replace the pump and the valve body
when i press the trim button up it just gurgles in the revisor and will not lift it up unless i help it lift then it will stay in place 100% when i press down it goes down extremely fast with no problem
I made sure all connections where tight and that there were no leaks up anywhere obvious refilled went up and down about 10 times while helping it to let any air out and still no luck still wont go up but will go down?
Took the manual release loose while motor was up and it went down like suppose to, Tightened it back up and nothing but gurgling again? when you look in there it looks like the fluid is moving but just in the revisor itself but not a lot of air bubbles in it?
