C
Chris Hofman
Guest
" Hello All,
I replace the w
" Hello All,
I replace the water pump on the engine and when I took it to the water for a test run the water from the indicator came out vary weak at idle and then not at all when I throtled up. There was no horn warning for overheating.
Is there a way to make sure the horn is working correctly I just purchased the boat.
Also I was able to engage the trans into reverse and turn the drive shaft while I had the lower off. When I had it in the water and shifted to Rev I got nothing? Any Ideas on that would be helpful.
Lots of thankd in Advance
Chris Hofman "
I replace the w
" Hello All,
Chris Hofman "
