1987 Stratos bass boat/ Model?
cws68
I came across this 1987, Stratos bass boat 18' with a mercury 150hp motor. On logo under Stratos it says Nashville which has confirmed it exist, BUT my question (hopefully not sounder stupid) What model is it? I can't find it. For instance there are 178v, 178F&S etc. anyone help with this would be appreciated so maybe I can find a manual
Sometimes, it will show up on the title and or registration card....
the other option is the check for the nomenclature plate...it will have the HIN on it and pretty sure the model as well.
Registration nor title have that info unfortunately
If you cant find the nomenclature plate, the HIN should be on the transom....around the rub rail line on the transom (check the RH side first).
with that you can do a google search and probably get more data than you want...
Thank you I'll look
