The Waco Kid
The 30 year old 15 HP Johnson starts! Runs hard and fast. But not for long. I did not time it, but seemed like 1 to 2 minutes. Dies, won't restart unless I pressurize with the bulb on the gas line. New, ethanol free gas in a nearly new plastic tank and hose. 50/1 mix with synthetic 2 cycle oil. If this was a car I would suspect fuel filter. Or the screen at the intake in the gas tank, with sediment in the tank. Tank is clean. Any advise?
Also, while it was running a gray goo was seeping out the propeller opening. Motor was hooked with muffs to the hose, mild pressure. Do I have leaking seals around the prop shaft? Seems to only leak when running.
Thanks in advance!
The Waco Kid
Thanks in advance!
The Waco Kid
