I am working on a 200 H.P. Evinrude (1989 ). Looper. Someone else rebuilt this engine and when the guy brought it to me to check out, I ran through the normal spark test and found that it was only firing on 3 cylinders. My visual inspection found that there was no shift interrupter swith at all, he bypassed that. I installed a shift interruptor and performed more test and found a bad rectifier/ regulator. got it all put back together and started it. it fired on all 6 cylinders. I went to shut it off and it appears that the key switch only killed 3 cylinders. So, I pulled plug wires, got it to die. Now, I go back to my spark test. I found if I leave the key switch in the off position, I am getting fire on 1,3 and 5, but nothing on the other bank. I used a screwdriver to push down on the shift interrupter and then I had no spark at all. shouldn't the key switch kill spark to all 6 cylinders? Please understand, I found several butt connectors under the power pack where the guy who did the rebuild rigged up some stuff and somehow he by-passed the shift interrupter. I need some assistance here please?
Thanks,
Chuck
Thanks,
Chuck
