1989 Evinrude 100 xp Shift Rod Connection
MichaelBarrow
I recently did a impeller replacement on my outboard and am having trouble re-installing the lower unit back in. To drop the lower unit i took the cotter pin off the shift cable bracket and was able to push in the cylinder connected to the bracket, which helped the lower unit actually detatch.
Now that I changed the impeller kit, I tried to reinstall the lower unit but it would not fit all the way in nor can i figure out how to reconnect the shift rod. Based on what an AI told me there is supposed to be a screw that screws in to hold the shift rod onto the upper unit but I never had to unscrew anything to get the lower unit to drop. I just simply pushed the bracket-cylinder in to release the lower unit.
In another video I watched on this that looks exactly like the interior of my outboard, the user was able to fit the shift rod in a gap made by the bracket-cylinder being pushed in and then was able to pin the rod once he pulled the bracket-cylinder back. However i cannot feel or really see a Pin connected like the one he has either.
Does anyone know what I might be doing wrong or if im missing something? Also was wondering if I will have to take The front plate and carbs off to access this?
If you can get a picture of where you are having the issue might help ones visualize your issue.
Also, if your shifting cable is still attached, is your lower unit and shift handle both in neutral?
I think when I did it, I disconnected the cables to make it easier to line up the pin with the hole in the shift rod.
