I recently bought a new sierra tachometer for my boat as it did not have one installed when I got it, when I go to crank the motor the tachometer reads while it's cranking but the moment it fires and the motor starts It drops to zero, I've tried idleing it up, changed the pulse setting and some other oddball stuff but alas, the same result. So as seeing I need to give answers to get answers I took some readings, all were taken on fluke 87 true RMS with the battery switch on and no other accessories running. Battery read 12.18 volts post to post
Gray to ground = 12.22v when key is on or when the motor is running
Purple to ground = 12.22v when key is on or when motor is running
key is off
gray to black = 12.18v
purple to black = 1.020v
Key is off
Gray to purple = .380v
also there is a 3 pin connecter in the motor that's not connected to anything that looks like the one for the tach, but it has a brown, black, and gray wire running to it, and there's also one standalone brown wire that's not connected, are these for the VRO pump, mines premix btw, any pointers to get me going in the right direction is appreciated
key is off
Key is off
