I was sure I posted this last night, but I don't see it. Sorry if it duplicates.
I have a 1990 8hp Johnson that ran fine a couple of years ago, then started acting up (surging, hard start, bad idle) and then it sat since then. I decided to get it back on the water. The motor will kick over (hard) with some starter fluid but will not run for more than a couple of seconds (even by misting some starter fluid to the carb throat). Here is what I've done to try to work through it:
- new correct plugs
- testing spark (jumps gap)
- replaced fuel pump (Sierra 18-7350)
- cleaned and blew out fuel line from pump to carb. With the primer bulb, I get good fuel squirt from that hose
- removed carb, opened it up and cleaned it out and blew it out best I could without a rebuild kit
no difference. Is the next step to do a full rebuild on the carb? Other ideas?
thanks all!
- new correct plugs
thanks all!
