Matt Ioder
The shallow water drive bracket on my motor hangs loose and I believe there should be a Spring or something to hold it in the place.Does anybody know the part number
I'm not following what you mean by "shallow water drive bracket". The only spring I see on the midsection is Part #0303979 - Reverse Lock Spring. If you could post a picture and highlight the part in question it would be helpful.The shallow water drive bracket on my motor hangs loose and I believe there should be a Spring or something to hold it in the place.Does anybody know the part number
Resize your photos to under 1MbI tried posting a photo, says to large for server to process. It's not the reverse lock spring, I've replaced that in the past
#76 is attached to Part #0303979 - Reverse Lock Spring as I linked previously. It is pricey at $44, but worth it if you want the engine to stay down when running in reverse. You might also contact Tim's Outboard to see if they have a good used one for cheaper.The bracket I am talking about is #76 on the midsection diagram. Mine is loose. By that I mean it swings around. I believe there should be a spring attached to it
It's not this spring. I've replaced this in the past#76 is attached to Part #0303979 - Reverse Lock Spring as I linked previously. It is pricey at $44, but worth it if you want the engine to stay down when running in reverse. You might also contact Tim's Outboard to see if they have a good used one for cheaper.
What I want is when I manually trim the motor up. The shallow water drive bracket goes into position.It's not this spring. I've replaced this in the past
