1993 6 HP conversion to 8 HP?
y knot2
I have an Evinrude 6hp and heard I can replace the carb or jets in the carb and convert it to an 8hp. Is this true? Has anyone done it? What parts need to be replaced?
Thanks for your help!!
There is a bit more to it than just the carburetor.( urban myth # 1 in outboard land )------------------Look it up on------------- shop.evinrude.com------------you may find that the 8 has more reeds and an additional plate on the exhaust cover as well.
I looked the possibility for a slightly older model
Not only different carbs, manifolds and reed plates but a different crankcase and cylinder
As above check the whole lot out on the parts lists or you may well be disappointed
I think for 1993 models the manifolds and reed plates may not be different but the crankcase/cylinder assemblies are!
