I have a 1994 Evinrude 200hp with a 25" shaft. I removed my gearcase to troubleshoot another engine, and got that one fixed. Now I have 2 gearcases I want to test on my engine, but I have questions.
First, I need to determine for sure what type of gearcases I have. With the shift rod pulled up (Forward) I turn the driveshaft clockwise (looking down at top of driveshaft) and the propeller shaft turns clockwise. If I understand correctly, that indicates a counter-rotating gearcase, is that correct?
Second, I have looked at multiple parts diagrams and they don't all agree. There seems to be a requirement for a "sleeve" on top of the waterpump outlet that is different length depending on the shaft length. When I removed my gearcase initially there was no sleeve, just a grommet. I can't see on the parts diagram where a grommet is required.
If someone can tell me if my conclusions about the gearcase rotation is correct, and also tell me what sleeve/grommet combination I need I would greatly appreciate it. This site is "the boss" and has helped me save a bunch of money over the past two years I owned this motor. Thank you all for your time and consideration.
