Hello Pros,
I inherited this motor, but unfortunately the water pump assembly was ALREADY removed when I got it and I am trying to put it back the way it was supposed to be. I am stuck at this point because:
1) I cannot slide the drive shaft down far enough for the pin to lock against the water pump (please see pictures). I tried rotating the prop while turning the shaft at the same time to see if it could go down any further, but no luck. I am waiting for a manual I ordered from ebay but I need your help now to get this done.
2) There are two plastic washers that I thought would slide on the drive shaft and go on either side of the impeller. However, they are too small to slide onto the drive shaft, and looking at the parts diagram, I don't see these two washers anywhere near the water pump housing. Do you know what these are for?
For some reason, I can't upload the files here so I stored it online. Please see the pictures from the links below. Thanks in advance.
https://ibb.co/PmKjSKd
https://ibb.co/xYB2wz8
https://ibb.co/gVKWSq4
https://ibb.co/6yZV6yW
