I am not sure which two cylinders fire for idle (its a 2+2 motor), but appears I have no spark on all 4.
I am assuming that I have a wiring issue somewhere and here is why.
Previously had a 1985 70hp evinrude, just swapped to this motor, and we ran my buddies boat the day before he pulled this motor off of it. I know it runs unless somewhere, something happened between pulling from his boat and moving to mine the following day. (unlikely)
Wiring harness to keyswitch looks like a birdsnest. My intention was to get it wired up and running, then disconnect battery and redo the entire electrical birds nest because neat wires are much easier to trace, and diagnose issues with.
I have power as starter works, t/t works.
Spark tester shows no spark on all 4. Confirmed spark tester works via lawn mower. I know I need new plugs, the end goal here is to get it running, then do annual maintenance.
I am guessing it is kill switch which I did not connect at the helm, so I will eliminate that at the engine side first and report back. I just don't know where to go after that if that's NOT it.
