fish brain
I have a 1996 Merk 150 offshore. It has always idled a bit rough, but I was told thats how they are.
Recently I replaced the reed valves, the newer ones are much stiffer than the old ones. I fired the motor up and it seemed to be running rougher than usual and I can't get it to idle below 1000 rpm. I called a local mechanic to have a look at it. Compression is fine and everything else seems to check out. He said take it out and give it a good run, and see how it settles in. I did just that. The first thing I noticed, is it seems to be way quieter. It really used to whine and now it hums if that makes ant sense. Initially the boat ran fine, acceptable hole shot, 30 mph at 5000 rpm. pretty much like she used to. I did several stop and starts, all good, so I gave her a 45 minute run. It ran like a top. I stopped to fish for about an hour, trolling on my kicker. Started the engine up for the run home, so far so good. But when I went to open her up she just quit. for almost 15 minutes the best I could get under load was 2000 rpms before she would stall out. In neutral she seemed to rev up fine except now she is puking blue smoke, a huge cloud. I ran it at 3000 rpm until it cleared up and put the boat back into gear. Still the same problem 1500 -2000 rpm then buhhh. Finally I started backing the throttle up and down, then all of a sudden she just opened up and ran like a champ all the way home. No smoke, no funny noises. I didn't try to shut it down and start it back up because it was almost dark and I had a bit of a run to get home. I'm going to pull the plugs and have a look at them later. Does anyone have any ideas why this might be happening?
