1996 90HP V4 Johnson OceanRunner outboard motor - NO start
johnnyc2024
Wondering if anyone knows the output fuel/oil pressure (at start-up/idle) of the VRO2 feeding the carbs. She starts momentarily upon spraying starting fluid into the 4 carb throats, right before key is turned...then stalls once the starting fluid is consumed. I'm using new 89 octane/non-ethanol gas, new plugs, new wires, new coils, new power-pak, & optical sensor. As a quick test, I plan on by-passing VRO2 pump and Separation Chamber and feeding 50:1 fuel mixture directly to the 4 carbs but need to know at what pressure.
thanks for any guidance/advice,
John
Near as I can tell there is no oil pressure spec that means anything at the carbs. The oil gets metered into the fuel chamber inside the VRO2, so all the four throats ever see is fuel pressure. Fuel side sits around 3 to 5 psi. The fuel only replacement pumps are rated 3 psi and up.
So the bypass test needs very little. Squeeze the bulb hard and hold it while someone cranks. If it fires and keeps running, the pump is your problem. No electric pump needed for that. If you do plumb one in, keep it low, 2.5 to 4 psi. A high pressure EFI pump will push past the float needles.
Before buying anything though. It runs on ether and then dies, so you have spark and compression. Check the pulse hose to the pump first. The fuel side runs off crankcase pulses through that small hose, and on these loopers a cracked or gas soaked pulse hose is common. If it smells of gas inside, the diaphragm is done.
I would also look at the electric primer. Cold start enrichment on your motor is that little solenoid on the intake with the red lever, not a choke plate. If the lever got bumped to manual, or it does not click when you push the key in, it will do exactly what you describe. Pull its outlet hose and crank, it should squirt. Crack the float bowl drains too. Dry bowls and fuel is not arriving.
One caution on the bypass. When the oil lines come off, cap the nipples on the intake. Leave them open and you have a vacuum leak. FWIW I would try the bulb before buying any parts. thanks
Thanks for all this advice! And yes, i have spark and good compression at all 4 cylinders. I’ll let ya know what I find nxt, soon. Thnx again!
Hi miles2000:
I’m waiting for some misc parts to arrive. The parts will allow me to pump the manual fuel bulb w/ one hand and turn the ignition key w/ the other (in order to bypass the fuel/oil pump at start-up). I’ll let ya know if she starts soon.
Hi !
Today, I set-up the hand bulb and bypassed the oil/fuel pump to manually feed the 4 carbs with a fuel/50:1 oil mixture.
As I pressed the bulb multiple times [before turning/pressing the ignition key to ON/START] I noticed fuel leaking out of where the fuel rails' nipples press into the metal bottom portion of carb/s - I'm guessing the 0-rings on these nipples are bad and the carbs may not be 'seeing' fuel pressure at start-up....probably the reason why she still won't stay running after attempting to start it. (She does continue to start-up/run temporarily, for 3-5 seconds, after spraying starting fluid into the throats of all 4 carbs, just before turning ignition key.) What are your thoughts?
Could you suggest any additional troubleshooting tests I could run?
(As you suggested, I checked the electric primer solenoid and I do hear it 'clicking' while turning key to ON & pushing key in. I verified its red lever's position is indeed in the down position, i.e., rotated clockwise till it stopped in this vertically down position. I also removed the top 4 screws of this primer solenoid and checked its internal gasket - it looked fine...and fuel was present.)
Thanks for any further guidance!
