[email protected]
I've check the stator the switch output and the charge output are within specs. Check ignition coils with ohm meter it check out within specs.
Checked the kill switch it check out OK. So I ordered a new power pack. Installed the new one and tested the output to coil, nothing.
Then I thought maybe the oil pressure was an issue, so I checked the oil pressure, it was good. Oil switch seems to be OK. will be able to check that out better when I get this thing running. Its it possible I got a bad power pack, it was brand new in box. Don't know where to go from here.
Any help would be appreciated
