Jvalhenson
I am assuming I need a new rectifier regulator but haven’t been able to find anyone who had these same symptoms. While at idle I am showing 12.8-13.5 volts and the tach is not working just sitting at 0.
when I put it in gear and start to get on plane and the rpms start to get higher the tach suddenly starts working and shoots up immediately to 3000rpms or wherever it’s at and at the same time the voltage immediately shoots up from 13.5 to 16.5 and climbs to as high as 17.5 as I run higher rpm. From say 3000 it will be at 16.5 and climbs to 17.5 at 4500rpm and seems to stabilize there.
Confusing for sure and I figure it’s gonna be the rectifier regulator as I do not think anything else can lead to higher voltage like that and don’t think the tach being bad could be causing it do that? Anyone seen this or have ideas beyond just changing the rectifier regulator?
