Hi All,
Hopefully someone might have a suggestion on what i could check next on my engine.
Here is some back story
Just picked up a 88' Grady White Overnighter w/ a 97' Johnson 150 on the back.
compression all checked out good. seller started it right up and had it running on a 6 gal tank for us to show it ran (on land mind you) - he claimed the boat was sitting for a year and he drained the tank to store it.
he did mention however that he believed the oil portion of the vro was bad - conveniently we had a spare that worked since the last boat we sold had one so we figured we'd mix for now and install the pump later this week.
on the way to the harbor we stopped and threw in about 12 gallons of gas to the on board tank, threw it in the water; started driving it over to the spot....died...
i notice when we flipped the fuel switch on the boat however its showing almost half a tank. to my knowledge its a 65 gallon tank (most likely original)
Moving on, we started tinkering with the engine on the 6 gallon tank cause i believed a problem with the engine. it would running for maybe a minute then almost out of no where die out.
As of today, i installed the new VRO and used a non mixed 3 gallon tank and the engine for the most part ran in idle (in water) for almost an hour! put it in foward gear....fine, reverse....fine. so i figured what the heck, try the onboard tank now (since im officially confused as hell)
swaped the lines, engine goes back to dying out again. put the 3 gallon back and tried to crank it over and stall out a dozen times (i guess to burn out the "bad" gas from onboard) and it would go back to normal and idle.
so at the moment im wondering perhaps theres a problem with the onboard tank?? perhaps water in the tank? one think i did notice is some of the onboard gas spilled over board and would turn milky white when it hit the saltwater?! i've never seen that before....
i did also just installed a fuel/water separator which when i let the nozzle out the gas that comes out of the bottom appears fine.
if anyone has any suggestions i would greatly appreciate it. Ive been tinkering all week with the boat and driving my self crazy.
