390Express
Anyone have any advice as to where to start looking for trouble shooting no cockpit lights on the above captioned boat?
Lights were working at the beginning of the year, but stopped. Figured it was a bad bulb, but checked both back bulbs and they work fine. Definitely no power at the back bulb housings, as verified with meter. I can access the following areas:
1) Cockpit fuse box near the aft, where the battery switch is (no blown fuses, and no fuse that obviously controls the lights
2) fuse panel beneath the dash
3) switch panel
Switch has three wires, it did have one wire that fell off. I shoved it back on, no change. Not sure of the proper wiring for the switch. I will post a pic of the above three areas, and the back of the switch next time I'm down at the boat.
Question:
I did notice one light under the captains chair that I did not have an opportunity to pull the bulb out of, if that bulb is bad, would it kill power to the back two bulbs? Seems unusual, but figured I'd ask. It's the only quick issue/solution that makes sense. Nothing else has changed.
Another quick Q:
The boat has the late 90's rocker style switches. Some light up when they're "on" and some do not, is there a bulb that can be replaced to remedy this, or is this a replace the switch situation?
3) switch panel
Question:
Another quick Q:
