This outboard starts and idles fine but when you accelerate you feel the ignition cut out. I think it is going into fail safe mode. The 2 things that could cause this are low oil on the engine mounted tank and overheat. the oil tank is full. The red low oil level wire shows open. float moves freely. The 2 themo switches on the heads show open as they should when normal temp. Doesnt have water in fuel sensor. When I turn key on warning buzzer sounds. Is there a way to disable this fail safe mode?
