So one of my low-speed carb jets plugged up, and i believe it was a piece of fuel hose breaking down (thanks ethanol!).
I had replaced all fuel lines from tank to motor years ago with new A1 ethanol resistant hose.
It occurred to me when this happened that my fuel hose from the side of the motor cowl to the VRO (OMS), and from the VRO to each fuel rail was still original and possiblydegrading. SOOO, I replaced those lines with new 3/8 and/or 5/16" A1 fuel hose. But the issue is the new hose is so much thicker, my air silencer still seats on the rubber carb "gaskets" but doesnt seat quite as tight as it used to.
Will this be an issue (ie will it cause engine to run lean or anything)?
Thank you!!
Thank you!!
