Shorefun44
Hi, I hope you can help. I’m a new boater, bought it as my kids love to fish. I have some mechanical capabilities related to automotive, but first time working with 2 stroke.
I Bought the boat used last summer (2019); it had bad fuel leaks (fuel filler and vent hoses, fuel sending unit gaskets) and wiring issues. Replaced parts and wiring issues with proper marine grade products.
It was running but still had some idling and stalling issues. Put it away for the winter and this year in April 2020 started working on it. I Found the carburetor were leaking and 4 of the 6 bowls were cracked. I rebuilt all six carburetors (with Johnson (BRP) kits) including replacing the bowl and float assemblies; the VRO was leaking so I rebuilt the VRO (with Johnson VRO Kit), replaced fuel hoses and clamps. Success as there were no more leaks, no fuel smell.
Did additional preventive maintenance; Replaced spark plugs, primer solenoid kit (leaking at the top), fuel filter, primer ball, fuel water separator, thermostats, lower gear oil. It seemed to be running better except the idle is higher than it was, and I am unsure how to adjust that.
I have had it out on the water and it runs well when moving, had it up over 35MPH with more throttle left, so I think it is close to being right. But I don't like the high idle and the last couple of times out on the water it was coughing and running rough under 8 MPH.
I have read online, and it was suggested to do a decarbonization and since I had never done it and do not know when it was done seemed like the right thing at that point. I ran two cans of Johnson Engine Tuner through it following the directions and let the second can sit 12 hours in the engine before running it. It smoked and when it cleared seemed to be running a little better but would still sputter and stall when running slow.
I rechecked and cleaned the spark plugs also performed a compression test.
My plans at this point are to change all of the remaining fuel hoses around the engine and to check the vapor separator.
Any suggestions??????
1999 Hydra Sport 201DC with Johnson 150
