1999 Merc. 40hp 3 Cyl 2 Stroke Timing issue: Trying to set timing using cranking speed method. 2 different timing lights indicate 12 Deg BTDC. Target idle timing is 2 Deg BTDC. I inspected the wood-ruff key and it is intact and tight. I replaced the trigger and flywheel with the same results.
I manually determined TDC using a dial indicator and 0 deg is exactly where I expected it to be on the flywheel right behind the timing tick.
I've only come up with 2 possibilities here.
1. I'm Stupid
2. I'm Crazy
In search of a cure.
Thanks,
Wyatt
1. I'm Stupid
2. I'm Crazy
Thanks,
Wyatt
