Hi all
Recently I had my boat transported about 1250klms (almost 800 miles). I know some of the way at least it was done so without outboard support bracket.
When the boat arrived, it would not lower or raise. I undid the release valve screw and it lowered. then it worked again and appeared fine.
Next fishing trip same thing. wouldnt't raise or lower.
The tilt trim motor is working although it is an after market Caltric brand.
What happens now is that if the motor sits it wont lower or raise. unscrew the release valve and move the motor slightly and then it works fine.
One repair shop over the phone said it could be damage internally to the pump.
What do you guys think could be causing this
Thanks for your help
