I have been battling with this motor for a while. It started with a bad timing base and I replaced it. I had no/intermittant spark on #3. I have solved that problem and reset the timing and thought I was good to go it seemed to idle well. I took it out on the water and no power. Started pulling plugs under load and the #3 cylinder still wont fire. So I drove home and switched the #1 and #3 carbs and the problem did not migrate.
I also switched the #1 and #3 coil. I measured the power pack output with a DVA and everything was in spec. I checked the timing on all three cylinders by trisecting the flywheel and they were all in time.
I removed the #3 carb to check the reed valves and they looked fine. I cranked the engine to see them function and found fuel pushing up from the bottom of the crankcase thru a small notch in front and below the reed valves. I think the crankcase was full of fuel and this was most likely from crankcase pressure.
I removed the recently rebuilt VRO and verified the VRO seals were not damaged or leaking. The crankcase pump section of the VRO was dry and no signs of fuel. I applied 5 psi to the crankcase pump section of the VRO and I could not find any air leaking from the VRO and could hear the spring and diaphragm moving.
Does anyone have any thoughts on additional items to check or recheck.
