Captainjac15
I am no certified expert, but I have been around a lot of outboards and I/Os. I have a nice big shade tree in the back yard.
Current problem is with J25EVLSIC, 2001 Johnson 25 HP 2 stroke, runs rough, will idle fine at start up then quit within 1-2 minutes. Give it throttle and it dies pretty fast. 100% sure it is running lean. I can keep it going by choking the front of the carb with 1 finger. Still coughs a lot though. I ran it first time this spring and it fired right up and ran all day. Was stalling at low idle from time to time while trolling and it didn't seem like I was getting full RPMs at WOT... so I pulled the carb and bought a rebuild kit. It was Sierra (all I could find locally) and I will never do that again. Its all over the place. Some of the needle valve seats and micro tolerances were off by over a millimeter in the bowl. I Have set and reset the float to manufacturer specs 3 times now going back to the J/E parts. I Checked fuel lines, primer bulb...looked for air leaks, sealed main fuel lines with hose clamps. Checked compression- Good, checked Spark-good (jumping 1/2"), Installed new spark plugs. Checked fuel pump while turning engine over and delivery line removed from carb- good pressure. Blew out all fuel lines. Checked primer solenoid (modern choke)- good. I have had the carb on and off and re-assembled 7 times now. I am at a loss. Sucking air somewhere? thats all I can come up with for how it seems to be running and coughing intermittently, and the reason I can get it to stay running by choking the front of the carb with my hand. I have set the low idle mixture screw and it runs better if I go out 3 turns, but I know that is farther than it should be. Any help or direction from someone more experienced with this engine would be greatly appreciated.
