2002 yamaha vmaxx 150 2 stroke
r200
Had a overheat alarm go off so I brought it home and replaced the yamaha water pump kit and put it back together and still no water peeing out of motor.i even took it back apart to make sure everything was put together correctly. Still no water .put 2 new thermostats in it and still no water at all out of the pee hole.what if anyway to check to see if anybody know what to try.
The tubing to the pee hole might be clogged with some debris.
Pee hole water really has nothing to do with the water that is cooling the block and heads.
