Hi,
First post here. Sorry about the length.
I have a 2003 BF130 with 540hrs on it. I have had it for about 2 years and put 240hrs on it with no major problems. The only issues I have had were water in the gearbox & valve clearances due to the previous owner not following the service schedule & replacing the waterpump & checking valves.
Last sunday we were out fishing and after a few hrs the motor sputtered then stalled. It turns over & will kick but not start. If I held the trottle up about 1/3 it would start and run rough but stall as soon as I let off the throttle. I replaced the plugs out on the water but it did not change anything. I had no buzzer warning (buzzer is working).
The motor was serviced at 500hrs, plugs, oil & filters. HP fuel filter & valves done at 400hrs by local Honda tech at which time he stress tested it to 5000rpm with no issues. Fuel is fresh and from the same station I filled up from for over 4 years, filter/separator in the boat is clear as are the filters in the motor.
I have had a quick look today and following advise from other posts here I have checked the following.
- warning lights & buzzer when key turned on. All ok.
- Oil level - ok
- In 'service mode' there are no errors. Mil light stays on.
- Checked all connectors for corrosion in the ECU box.
- Resistance on primary side of both coils was 1.0 to 1.1 ohm. I will have to borrow a meter to get the secondary & pulse coils as mine only goes to 400ohms.
- HP fuel pump runs for 2 sec when key turned on.
I will try to test more during the week but was hoping for some help to maybe narrow down my search. If any one has had this problem or knowledge that can help it would be greatly appriciated.
Cheers
Craig
- Oil level - ok
Cheers
Craig
