I have a 2003 bf225, I was installing an automatic drain plug and in the process put the engine in gear to check clearance on my drain plug switch. I left it in gear while drilling and fitting the switch, and when I got to the rear of the boat noticed oil leaking out pretty good. Motor was tilted up in transom saver and I just assumed something crapped out on me. Upon further inspection noticed oil was coming from the shaft towards front of lower unit that runs up to the motor, assume its probably the shift shaft. Lowering the motor caused it to stop, also noticed when it was taken out of gear I could tilt up with no leak. My question is, is this normal or do I have a problem. Thanks for your help guys ?
