Hey everybody, need some help here.
After repairing a broken screw on the starboard side thermostat, we (a mechanic and I) started the engine to test things out. Well, water was leaking from the space between the block and the plate that the thermostat and timing belt pulleys are all mounted to. To be clear, water was not coming out from under the actual thermostat itself, there is a new O-ring and it seems to be working!
He filled the hole with a bunch of high test RTV (not the home depot kind!) and coated the screw in it as well before reassembling.
Anybody ever have this problem before. If so, what have you done? If this doesn't seep into the space between the two pieces, is my only solution to remove that top plate and rebed the whole thing?
As an aside, the repair I made to the cast on the port side thermostat last fall needs some attention as a little bit of water was seeping out. I read recently about drilling that out and tapping it, then putting a screw in - anybody try that? seems just as DIY as the steelstick!
Thoughts on both?
Thanks,
Chris
Thoughts on both?
Thanks,
Chris
