I have code 48-5 but I have replaced the air flow sensor with a OEM and it didn’t help. I checked the fuel pressure after the fact and I’m getting 38 PSI pretty consistently. When I disconnect the small vacuum line the pressure jumps up to around 43.
I replaced the pump with a Quantum primarily to test it bc the one in there was OEM and only a year old or so.
I have replaced all 3 filters (water separator in bilge, the cartridge in the small bowl, and the high pressure in the VST housing.
I’m leaning towards fuel pressure regulator bc I’m really not sure what else it could be.
FYI. I did run it on a portable tank and it didn’t change the PSI.
