She was finally started up today and purred like a kitten on muffs. We'll have to take her out to confirm everything is good.
Had a little issue before this with the carb bowl drain bolt o-rings leaking fuel. It was the new o-rings provided in the Johnson Carb Rebuild kits that were leaking so I ordered replacement o-rings from Marine Engine. Used some silicone grease on them before installation and no more leak, weird.
Last thing I noticed today was the timing cam/spark optical sensor lever thing was not returning/springing back to its closed position very easily. It would freeze up and not kick all the way back once you put the throttle back into neutral. Below are a few pictures. The first one shows it in the fully seated/closed position and the second one is me just moving it with my hand and as you can see, with my hand removed it doesn't spring back.
Curious if the spring in the third picture is just worn out or if I need to lubricate something. I do not want to just start spraying lubricant everywhere as I know there is a small optical sensor somewhere within the timing components. Am I totally off base with this?
