Good Morning.
I have a 2004 Mercury 115 ELPTS four stroke with a Mercury binnacle top mount control box with trim switch (88688a26).
My issue is at my trim switch at the control box. When I try it I get nothing, when I try the switch on my motor, works like it should. I thought it might be the switch or connections at the switch. Replaced the switch, nothing. Used my meter to test voltage at red wire 12.4 when touching the other lead to either the green or blue wire. I’ve tested continuity from the switch connections to the male plug under the console, same with female plug to female bullet connectors coming from inside engine at harness. If I unplug my main harness inside engine I lose voltage at switch, plug back in and again have voltage at switch, but no operation even if I jump red to either blue or green.
I have not done anything with the relays yet due to them working properly with the switch on motor. Is there a connection at the relay for the remote switch? I’m really puzzled and of course I’m heading to the keys in 5 days...
I want to add I just replaced my steering and shift cables, pulling on wiring I’m sure... Also replaced my trim pump which works flawlessly on the switch at the motor. The switch at the control box did work prior to me zip tying everything from the motor wiring grommet to the side entry grommet on boat.
I appreciate any help and your time on this matter.
Thank you,
~Ryan
Thank you,
~Ryan
