Happyprinter
As you know from a previous post I have had issues with motor cutting out when I got to about 3500 rpm on start up out of the hole. It was suggested to change all the filters which I did but did not fix the issue. I started at the bulb and replaced it then the low side fuel pump, then the high side fuel pump. I also removed the VST tank and opened it up measured the float, which was OK also. I replaced the vacuum control that sits on the top of the port side injector rail also. In going thru the fuel system I have not seen any water, grime or particles anywhere. Last night I pulled the fuel water seperator apart and cleaned it also. Now for the new issue. I hooked the engine up to the water cups and started it. It idled fine for a few minutes then I got a intermittent beep with the green oil light on. If I start it and run the RPM’s at say 2000 no lights. This is the first time I have had this error. Did I possibly not hook something up right?
