I want to replace the impeller and have removed the 4 nuts under the cavitation plate and also disconnected the gear linkage at the mid-point. It won't drop down but shows signs of separating at the joint. Without having a manual for it yet, is there something else that needs to be loosened or removed for the drive shaft and lower leg to drop down completely or is it just seized in there a bit?
Thanks for your help!
